I need Help
ama1703
How are you
i want some one help me in my final year project
My project about gried tied system by using solar power, so i want information and diagram in how i can build circuit that makes the output of the inverter synchronized with the gried in phase, voltage and current.
Thank you all
If you are look for working simple model, you will have to get line we the rest of us. Working "non grid tie inverter" models are available here and on the internet. If you plain on doing the grid tie inverter as a project. Plain on being in it for the long haul. I suggest that you take the first step (after lots of research,) and present you best ideas. You will then get hits on you ideas some to the left some to the right and some right on. You will have to sort through them a select the ones the best supports your project.
Good luck.
Making a simple GTI device is rather easy. :)
Making a safe, electrically clean, efficient, reliable, cheap, and legal one is much much harder. :(
Accumulating all of the information that a person would need to understand, and implement in order to build a device that meets all of these requirements is even harder still. :(:(
Just because a person has an education in electronics and electrical theory its not actually the same as having real life experience with working with fabricating and trouble shooting it.
All the theory and simulation software you can buy still doesn't equal real life hands on experience. ;)
As someone who has built many of them, trust me, simple, illegal and rather unsafe but reasonably efficient GTI systems are cheap and easy to make. Adding everything else thats needed is where the real work comes in. :)
Getting all of that other information directly from someone who knows the stuff beyond the simple, unsafe, and illegal part is nearly impossible!
For some twisted reason people with that knowledge just seem to think that everyone else should have to work for it too! :D
