I need equilant of IC " SF 5101681B "
Ayazhaider
Hi!
I have LG StudioWork 77M, 17" Monitor with build in Speakers.
The problem is that.. It won't power on..
The supply is ok, at power button it have 5v, the print from power button to IC (pin marked with KBT1 ) is also ok. I replace the touch power button and tried to short with twisser but it still won't On..
I think the system IC is out of order (on IC i had 5volts).
does any body help me to find any equilent of following IC.
(M)
SF5101681B
LGM 012-600/BYJ
Monitor Details
LG StudioWorks 77M
Model : MB776C-NP
Thanks in advance
Sceadwian
Banned
Your best bet is to contact LG directly and see if they allow you to order replacement IC's. That's probably a proprietary in house IC, you're not going to find it anywhere.
Nigel Goodwin
Super Moderator
Most Helpful Member
Yes, when he says "system IC", presumably he means the micro that runs it?, which will be a specifically programmed device, only available as a spare part from LG.
However, it sounds like he's just made a random 'guess' at that been faulty?, I would have thought it's one of the less likely options.
Ayazhaider
Yes, its my guess that IC is out of order.. or may be not.. :confused:
I tried to get info from other resources too.. I Got Schem Diagram and Part# List.
the part# of IC is IC301 / 0IMO786220A Vendor Motrolla.
any help to get any equilent IC of any other vendor ???
Nigel Goodwin
Super Moderator
Most Helpful Member
What makes you think so?.
Like I said, if it's the micro-controller, then it's specific to that single set, you can only obtain it as a spare.
Ayazhaider
Spare not found here at my town..
Anyway i will try again by tommorrow,
:) now feeling sleepy Going 2 bed to be recharge mySelf....;)
EE World Online Articles
Loading
