I need a 2 source - 12 Volt switching circuit
tuxamiga
The closest circuit I have seen is the schmitt trigger.
If 12 volt source A is turned ON, then 12 volt source B is turned OFF,
else 12 volt source B is turned ON.
Any ideas? Thanks
Any ideas? Thanks
What are the sources? You might be able to do it with just a diode. Otherwise, how about a relay?
Relay spst-no + spst-nc 5a 12 vdc
Yes, this relay will work.
I was checking to see if there might be a solid state circuit that could do the same thing.
Thanks for your input.
