How to remove black protectant from tiny ics.
crater
I'm curious if anyone knows the best way to remove the black "dot" covering micro ics. I have one of those stupid flasher light buttons and would like to use the ic from it, but how can I remove it without destroying the ic? Is it possible? ie solvent, exacto knife? Just curious.
Thanks in advance.
kinjalgp
Active Member
I suppose you are talking about ICs that are directly fabricated onto the PCB. These are called COB (Chip On Board). There is no way you can remove the top cover whithout damaging the chip. If you want to use it, you need to use the entire PCB. Solder wires at required points and use it in your circuit. Thats the solution!
