Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
I'm guessing that feeding it 450V DC gives a reading around 320V. This is due to it reading the peak AC voltage. The only way to get it to work properly is to remove all the components and replace them with one series resister. The resistor value should be the existing resistor value times 0.707. This is again a guess but if it does read 320 instead of 450 then probably correct. More info on the components, how they are connected and the meter would be useful.
Edit, you want a resistor at least as physically big as the existing one. Preferably bigger (Wattage wise).
show us the face of the meter, what dc voltage are you going measure? The same meter can be used for 10 v or 1000 v, depends on the series resistance to get the correct current. Do you know what the Full Scale voltage or current is? usually shown on the face of the meter.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
