How to double a variable freq
zhassan
Hi
I need some help in designing a frequency doubler circuit. The requirement is that i have a signal comming from a motor which starts from 0hz till 1.2khz.
My plans is to quad the I/P frequency (using NAND gates & NOR) and then 1/2 it with a flip flop. Hence getting a doubled frequency. :D
Firstly i did managed to make a freq doubler circuit with a RC circuit but this can't work on a variable freq because it will overlap freq's.
How can I do this :confused: Plz guide
There are a few ways.
Have a look at PLL circuits (phase locked loop)
Sample the input frequency with a microcontroller and write some software that varies the output frequency vs input frequency (I have a product that does this for cars)
Use a Frequency to Voltage converter and a Voltage to Frequency converter together
will look into PLL
thanks for the reply. I'll look into PLL circuits. Why do i have to sample it? the input freq. is a square wave.
Plz let me know if i'm wrong.
Those were 4 different ways of doing it. I really should have put bullet points or numbers on them ;)
1. use a PLL
or
2. Use a microcontroller
etc ;)
If the doubled frequency doesn't have to be symetrical you can just trigger a one-shot at the rising edge and at the falling edge of the signal. This will give pulses at double the input frequency.
