I purchased a chinese cnc ethernet interface. The step motor signals are +5 , step pulse and direction pulse. However, my step motor drivers require a step pulse and direction pulse and uses common signal ground for the return path. Is there and easy way to convert the +5 signal return to common signal ground.
Here is the manual and you can see in section 2.2.1 https://www.makerstore.com.au/download/publications/ELEC-NS-U-Manual.pdf and 2.3 show how to wire the motor driver.
Here is the drivers that I intend to use
https://www.geckodrive.com/amfile/file/download/file_id/22/product_id/14/ Page 7 You'll see that pins 18-25 are all signal grounds for the 4 axis inputs.
