how to control dc motor using P16F84A?
aerial
hey guys need help here....im using P16F84A for controlling a motor..no idea how to..the motor runs upto 6 volts ..i try to connect directly the terminals of the motor to the PIC i think that was a mess coz the output of the pic cant drive the motor..any idea?its for my project
You are correct, the PIC can provide the voltage but not the sufficient current to drive the motor.
YOu need to use drive transistors or something. Google H-bridge. It allows you to change the direction of the motor. And if you PWM the H-bridge instead of just off or on, you get speed control too.
I recomend using the 16F628 and a PWM motor driver IC controled by serial interface. The 16F84 does'n have one and 16F628 is newer, cheaper, available, better.
what ever the microcontroller you are using, and what ever technique (PWM, DC..) use a ready motor driver IC like the L293D or the L298 for higher currents.
Really it will work perfectly, and takes very litle space.
