How to audio drive a 300 ohm flat piezo speaker ?
Device takes less than 20 V pp; so use an amplifier with about 15 volts rail supply; I think the LM386 IC can do it, connect as if it was any plain speaker per IC data sheet.
Check the datasheet to make sure that the 386 is happy (unconditionally stable) driving a capacitive load such as a piezo speaker.
I can not find much info on driving a 300 ohm load like a headphone with a LM386.
Has anyone seen anything?
Sounds like crap, but I think this video pretty much says the LM386 will work, don't know about 'unconditionally stable' but functional at least.
What sounds will the horrible-sounding piezo transducer play?
Its loudness is very low and since it resonates at 1800Hz then it will not produce low frequencies.
It might produce faint childrens' voices pretty well.
