How does a transformer work?
Sceadwian
Banned
Using a transformer to increase current will decrease voltage.
seis78
I can get over 30 volts with my generators, some accessories that will be plugged into it will have the transformers in it not the generator. So loosing the voltage will be fine as long as it's in range. If it'll work this way.
Sceadwian
Banned
30 volts under load? Use a 2-1 transformer it'll half the voltage and double the current (at between 70-90% efficiency)
crutschow
Most Helpful Member
A 115V input, 48V output transformer would be reasonable close (2.4:1).
Grossel
Another aproach is to put an capacitor in series with the output of the generator. It will work if the output frequenzy is fixed = fixed generator rpm.
But you must find the generators internal reactance to be able to calculate neccesary capasitance.
duffy
Damn those are cool, seis78.
I'm afraid a transformer probably won't work, the stepper generates 4-phase AC in generator mode, a transformer wants single phase. Can you use a lower voltage stepper motor? Otherwise a switching regulator module would be your best bet.
seis78
Hi Duffy,
No I can't use a lower voltage stepper motor. But I was thinking to add the transformer to the accessory not the generator. I believe this is how the Plasma ball accessory I use is powered by my generator, but I could be wrong and this is why I am here.
Thanks for any help
crutschow
Most Helpful Member
Doesn't make any difference where you locate the transformer.
Grossel
What does accessory in this term means?
As a no native-english I cannot manage to guess. Tried a google search didn't provide any answer.
EE World Online Articles
Loading
