How do I interface an ESP32 PICO D4 with a CP2102N?
Sashvat
Hello everyone, I am trying to make my own custom board for which I am thinking of programming the ESP 32 microcontroller via USB. I have seen the PICO D4 Development kit which uses a CP2102N but not sure how to use it. I am trying to keep my PCB as small as possible so I am thinking of using the QFN-20 package. Would like to know how to connect it to my MCU.
Here is the data sheet for the CP2102N-https://www.mouser.com/datasheet/2/368/cp2102n_datasheet-1634912.pdf
Thank you
Here's a good start from the EEVBlog forum. This gets you the USB side (data and power).
On the microcontroller side, remember RX-->TX and TX-->RX (i.e., they are swapped.).
cp2102n-uart-not-detecting-on-pc
That appears to not use Vusb but a separate 5V supply. Actually, two - 5V and Vdd - how strange.
To the OP, the schematic for the Wemos Lolin ESP32 board is freely available.
Edit, the modules are available from banggood for $5½.
Schematic.
Thanks, I am thinking of using the 20 pin QFN package but DTR is missing would that be a problem?
There is also a "Battery Charger Detect" function that is available. My project does use a battery. I am not able to understand its function. What does it do?
I think DTR is used to reset the processor when the software needs to talk to it. The QFN24 has DTR and is only 4x4mm.
Woops, sorry that is obviously a version with a battery. If you google ESP32 schematic, there are lots available.
right, but the 3x3mm qfn 20 doesn't have DTR, I sometimes use an FTDI board without DTR, would that be ok for me? Is DTR necessary when dealing with UART?
The circuit above is designed to run off a single Lipo battery and charge it when the USB cable is plugged in. Will this do what you want?
Is it the circuit you shared? But I have a different battery charging IC not the tp4054
I see there is a DTR pin that is not used and is NC. Is that ok? So now If I follow this circuit (even with the QFN 20 package) then would it be fine?
If you look at both the schematic I posted and the one you did, they both use DTR along with RTS to toggle the EN line on the processor. So, I think you need the DTR line. Which battery charging IC do you have?
