How can I do this?
any particular reason?
Anyway you prolly want one that has a high lumen output (ie can handle abt 50mA) to get the brightness. Then all you will need is the LED and a burn resistor.
NOTE
watch rating of the burn resistor
Burn resistor? ahhh... is that a limiting resistor or not?
yeh same thing as a limiting resistor. just pry the pins out using a tiny screwdriver cut the plastic walls away. solder leds on and cover them with heatshrink to compensate for the missing plastic wall insualtor.
simple.
@ pike
WoW...that sounds great and easy, I'am gonna try that...
