How Can I Display a Circuit in a Post
LouisStraub
The majority of my questions are about problems in the Floyd book. When I'm unsure of an answer to a problem, I draw the circut in MultiSim and try to work through the problem using a Multimeter. However this doesn't always work as MultiSim displays the correct answer but I can't figure how to arrive at the answer. Is there any way I can display a MultiSim circuit design so I can be very specific about my questions. The extension is .MSM which unfortunately is not a valid attachment for your website. If I can't, is there any way I can draw a circuit and make it display as part of a thread. This would be extremely helpful to me as a picture is worth a thousand words..............
Anything on the screen of your pc is copied with the Print Scrn key. Then paste it into Microsoft Paint program and save it as a PNG schematic.
You are still a Noob so a moderator must accept any attachment to make sure it is not SPAM.
If you just want to copy an active window on the screen, select it, press and hold down the 'ALT' key and at the same time press the PRNT SCN key.
Nothing will seem to happen when you press the PRNT SCN key!!, but the image is copied to the clip board.
As explained, then paste into your picture editor.:)
Uploaded MultiSim/Word Document
I don't have Paint, but you gave me a great idea. I copied MultiSim into Word. I then used the Attachment function to upload the file from my computer. It uploaded ok, but I can't find it??? I want you to see the upload in this REPLY. How do I show an uploaded file in either a Thread or a Reply? These may be simplistic questions but I'm not use to the software for this site so navigation is cumbersome. Thanks.............
As a new user you will have to wait for it to be moderated
Yes it worked, but you're better off posting a circuit as a GIF or a PNG than a PDF.
Agree.
For scanned documents (handwritings) - Use JPG (don't scale it too small).
For screen copy (if using windows) I recomend Faststone Image Viewer and save the pictures as PNG. It gives good image compression (small size compared to other formats).
Vector format like GIF or PNG do not scale well and the result is horrible.
Many GIFs after scaling is unreadable as many have found out on numerous websites.
JPG, thanks to its fuzziness, scales better than GIF or PNG. A circuit starts its life as JPG but then save as GIF can sometimes be even bigger in file size.
The guideline is, try both GIF/PNG and JPG format and then decide on which to post. File size and clarity matters and sometimes one cannot have both.
You shouldn't need to rescale it, create it at the correct size in the first place.
GIF and PNG are also NOT vector format.
You should never start with a JPG, as their quality is far too low. Once it's been JPEG'd you can't get it back to GIF or PNG, it's like trying to recreate the original egg from the scrambled eggs.
For electronically generated diagrams, use GIF or PNG, the quality is 100% and the file size is FAR smaller than a fuzzy JPG.
This is a test of the .jpg format for the circuit diagram
It's 197KB - far, far larger than it needs to be.
First obvious thing is not to post such a massive image, it's much bigger than my screen size, and consists mainly of empty space. Give thought to your attachments, minimise white space, and crop to a sensible size.
Posting an image like that (a simple diagram) as a GIF/PNG will also probably be less than 1/4 of the size of a JPG.
And here, for comparison, the same file executed in GIF, JPEG and PNG:
GIF 18K
JPG 69K
PNG 209K
VERY bad comparison though, the PNG file is huge because it's derived from the JPEG, where the quality has already been lost (you can clearly see the JPEG defects in the PNG file).
You need to convert the JPG from a 100% quality format, not the other way round - or was this just a deliberate attempt to make PNG look bad?.
These are the fuzzy ways that most JPG file type schematics are posted:
GIF 18K
JPG 69K
PNG 209K
They were all derived from the GIF file.
Edit: Or at least they were meant to be. I would not deliberately favor one over the other for I don't care. I was merely showing the difference in the three methods on this system.
