High voltage startup circuits of flyback controllers (NCP1239 & NCP1219)
Flyback
**..Question 1..**
In AND8393 page 2 it shows a diode (D13) and two 1206 resistors (R41=R42= 1k82) being used in the HV startup circuit to NCP1219.
The startup current is only 12mA and only flows for some few hundred milliseconds at startup, so why bother to use all these components?
Why not just have say two 0805 resistors (ie not 1206) coming down from the HVDC bus, and not bother with the diode?
The power in each of the R41 and R42 resistors is a mere 260mW for a few hundred milliseconds at startup, so surely an 0805 would be fine?
Also, in AND9296 page 3 it shows two diodes (D1 and D2) and two resistors (R5 and R6) in the HV startup circuit of NCP1239.
The startup current of NCP1239 is only 3mA, and this only flows for a few hundred milliseconds at startup. During this few hundred milliseconds, the
dissipation in the R5 and R6 would only be 24mW. As such, why have 0805 resistors been used when 0603 would suffice? Also, why bother to connect them to the AC lines with D1 and
D2?...They could simply be connected to the HVDC bus without bothering with the diodes. The dissipation is so small and limited only to startup time.
AND9296
AND8393
You need to consider the voltage ratings of the resistors, generally higher wattage resistors have higher voltage ratings.
You also need to consider reliability, designers with only theoretical experience often put resistors in series as shown - these tend to be VERY, VERY unreliable. Resistors in series in this way commonly tend to go high or O/C, as new TV's, VCR's etc. were released you could predict which ones would have failing PSU's because of the use of resistors in series.
If they are specifying particular sizes of resistors it would be foolhardy to make them smaller!.
**..Question 2..still*
When the output voltage is too high the FB pin gets pulled low.
Thanks, yes, though i am not speaking of that particular use of the FB pin....that one may not shut it down..it may still switch on and just switch straight off....still letting some power through...like the ucc28c43 when you pull its FB pin low...it still lets thru some power. I speak of actually shutting it down, and making it not switch at all. In NCP1219B, pulling the FB pin to ground "does" shut it down...but does it with the NCP1239?
As you know , there is a difference between "shutdown" and "demand value pulled low but its still actually running".
Its like pulling the FB pin down doesn't always shut down a PWM controller. By pulling FB down, what you often do is just ground one input to the PWM comparator....and the demand input is also at 0V....so you have a comparator with both inputs at 0V...and the noise often makes it trip....the noise can make either input look higher than the other, depending on what ambeint noise gets picked up by either input.
**..Question 3..*
Pages 11 & 12 of the NCP1203 flyback controller datasheet say that the connection of the NCP1203 to the HVDC rail via its HV pin (so that it can start itself up)
can also bring about catastrophic latch up of the NCP1203.
It says that series resistor values of >4k7 must be added in series with the HV pin to avert this danger.
One presumes the entire NCP12XX range of controllers are also susceptible to such disaster?
Though why not just insert a 400V SOD123 diode in series to the HV pin instead? The diode would stop the reversing current inherent in latch up.
Also, it would dissipate hardly anything since the startup current is a maximum of 18.5mA and diode Vf is only 1V.
So in the schem of page 2 of AND8393, why do they use D13 & R41 & R42? All they needed to do was connect D13 from the HVDC bus to the NCP1219 HV pin and its job done?
A SOD123 is only 3.85mm by 1.7mm, so its smaller than the two 0805 resistors that onsemi always recommend with the NCP12XX application schematics.
So why are they using resistors when they don't need to?
It cant be too disallow startup below X volts because 3.64kOhms x 5.5mA is only 19.8 Volts.
NCP1203
NCP1219
NCP1239
AND9296
AND8393
Thanks very much .. and well spotted, sorry for spreading them too widely......as you obviously know well, NCP12XX is a great family of controllers, so these qu's will be of value to a great many folks
**Question 4..**
Would you say the below output overvoltage
protection circuit is OK? How much current is it safe to
put into the latch/skip pin? Datasheet doesnt say.
Output overvoltage protection for NCP1219B...
NCP1219B
