Hello
I have designed a MPPT Buck controller which feeds a battery and the battery is connected to a DC-AC Inverter.
My Panel Voltage is 60Vmp and 67Voc at 30A max power (Isc is 36/37A)
I try to keep the PV voltage at Max power using the P&O algorithm.
For starters i kept the PV voltage at 60V. I limited the current to 20A.
I connected a DC(48V)-AC (230V) inverter at the battery.Loaded the inverter with a 1200W load so that it demands a 25A current.
What i presume : The Inverter Load will demand current from the PV over battery since its
Vo/p= 60V-MOSFET drop- choke drop- protection diode drop = 54V.
What i see: The panel current never crosses 12A although its capable of giving 30A (limited at 20A of course) at noon.
Can someone explain what's wrong?
