help on C coding
Emantra
i need help on the C coding, i need the C program to convert the voice signal that is feeded to it throught the mic to convert it to the electrical signal that can be feeded to a microcontroller and can turn a motor.
and i have a very little knowledge about the C programming
i dont know if this is the right forum for the programming or not, i thought that it is related with the hardware section too so i write it here
thanks for any reply
Well your mic will convert the voice signal into an electrical signal :)
I think you are looking for is depending on the voice your motor should run right???
yes
yea that's what i exactly what i want. i want to convert the voice signal to electrical signal and then run a motor that could open or close door on the basis of voice command like "open" to open the door and "close" to close the door.
your help might help me a lot.
thanks
reply
Why not go with a voice recognition chip?
I have a automatic door opener for my room and I used a winshield wiper motor and a voice recogniton system and a remote control which turns the relay on and off.
Uncle_sam
If you go by designing the circuit/logic/program to recognize the voice then it will be very complicated
because depending on various factors like voice of a person, surrounding noise, etc. the electrical signals generated by mic will vary.
So its recomendded that you use a voice recognition chip as mentioned by roboticinfo.
It will make your life easier :)
yea but.....................
my first assumption was to use the voice recognition chip but the factor was that it was pretty hard to find that chip in my place, Nepal. so i had to switch to the programming logic. the vendor from which i bought other thing said that he could get it, but the main thing that it cost was the time factor coz i dont have that much time to wait for the chip to arrive in time, so i switch the logic.
if u guys has better idea than using the programming n the chip then that is pretty appreciated, or if u guys can get me the ICs number used in that chip and the schematic diagram for the voice recognition chip than that too will be appreciated
thank you
