help on a drag race project
koffijunior
hello am working on a drag race project using LED, servo motor, IR detector. am trying to build IR detector and am stuck with the program in Pbasic. it is not working as expected. please i need your help. thanks
i need to build a kind of LED tree to work as shown in the picture attached. to make it more interesting, i want to add an IR detector at the beginning and the end of the race. the one at the beginning will prevent a car to cheat, if a car starts before the green light, the red light at his side goes on. the one at the end will show which car cross the line first, then a servo motor will turn a flag to his side. all is controlled with an educational microcontroller board with a program in pbasic. am stuck with the circuit and the program of the ir detector for now. thanks
I recall a vintage circuit in 99 I.C. Projects 1980 magazine called "Slot Car Race Referee" that didn't use a controller. It follows the process that you described. Find it online at www.scribd.com .
