HI, i'm building a keypad circuit to switch a relay. I got the circuit from
I don't have a proper bench power supply so am using aa batteries in series to give 7.5-9v. When i start testing it works for a bit and then tranisitors 4 and 5 seem to stop working i.e. Q5 wont turn on when E is pressed, Q4 wont turn on when there's an output from pin 10
Does anybody know why this would be?
I plan to put it in a car. Will the car battery fry Q5 straight away?
Is there another transistor that is more durable than BC547? Or are they usually ok and it's just something i'm doing??
Cheers for any advice
Also, i had to remove Q1 and Q2 cos they seemed to reset the cascade whenever they were pressed, even if it was at the right point in the sequence. I ran the circuit on a circuit simulation software and it didn't work with Q1 and Q2 plugged in. Any ideas??
cheers :?
cheers :?
