Help! Designing a SMPS
varun
Hi!
i am new in the eletronics and i wish to make a SMPS of output rating 12VDC-1Amp and input anything from 180V to280VAC,can someone please help me in getting the schematics and other related information for the same. Waiting for reply
varun said:
Hi!
There are lots of suitable chips for SMPS use, the main problem is likely to be the transformer. If you go to rswww.com and search for TDA4605-2 there's a link to a datasheet, which gives an example of a PSU for a TV. For your application the only change would be to the secondary of the transformer.
But if you're new to electronics, perhaps an SMPS isn't a good place to start? - it's the sort of project which can get through a serious amount of blown parts until you get it right - plus it obviously has dangerously high voltages.
thanks for the help!
hi! NEIGL
thanks for the help and but the sit u mentioned is off line right now,i'll check it later and hopefully trouble u later in the future .hope u'll not mind.
bye
sorry
Hi! NIGEL GOODWIN
Sorry for the spelling mistake in the name ,hope u dont mind it any way :?
500W SMPS using SG3525 100khz
this is a very reliable smps, underrate it for any use.
the magnetics are a bit difficult to wind, but can be done.
see the SG3525 based SMPS
