Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Hi
i'm trying to control a dc motor with a micro-controller and I built H bridge like this **broken link removed**
Is it enough to drive the motors and supply enough current
I connected the pins of the controller to the resistances
Thank you
You need to make sure that the power supply for the micro is the same as the one at the top of the H. Otherwise you may not be able to turn off the top transistors. If the power is 5 volts the base current in the transistor will be about 4.3 ma. This is enough for the transistors to switch about 43 ma. So if your little motor measures about 100 ohms or more you can drive it. In reality you could probably drive one down to 50 ohms but things may get a little warm if it is stalled.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
