H-bridge: BJT vs relays
bananasiong
I need some comment for these circuit, their pros and cons.
Which one is better? which one drives faster and etc.. thanks
Basically transistors allow you to add PWM speed control, relays don't. If you don't want speed control?, go with the relays - it's far simpler!.
You can also do a hybrid version, a single transistor for PWM speed control, and a single DPDT relay for forward/reverse.
Oic.. i think the relay is more suitable for me. Is the speed controlled by 555 timer? How does it work?
bananasiong said:
Yes, i know.. Then how to control speed if the bjt is used?
By using PWM on the inputs to the H-bridge, usually generated directly by the driving micro-controller - good reason for using a 16F876/7 as it has two hardware PWM channels.
The relay cannot be used to control the speed just because it switches not fast enough?
how if, the motor is drive too fast, i want to slow it down, by using a 555, the output of the 555 is connected to the Vcc of the H-bridge. Can this work?
Yes, but NOT fed from a 555, you would need a high power transistor or FET to drive Vcc - and it's then fairly pointless using so many relays, a single DPDT one would do.
