station is Duratool ZD-915 I was changing the heating element , the short Goes to the solder handle , Its not the connector as I have just tested that now , I was installing a new heating element and I thought I had the wires in the right order but I didn't < I have disconnected them all apart from the ground which is the yellow wire to the blue . Black wire is pin one , pin two is the dark blue wire , pin 3 is the red wire on the right ,pin 4 is the red wire on left . pin 5 and 6 are from two white wires but I didn't need to touch them. the problem is how do I match them up with the heating element .Hi Dazer!
You should send here Brand and Model of your Solder Station...and maybe anyone can help you.
Best Regards!
