Guitar amp input info?
trikebuilder
going to build a small battery powered amp for a handicapped buddy, into the surface of the guitar bridge frame,(low power for headphones) (He like to sit and play, but it intrudes on others. He wants its small enough that we can fit to the guitar and leave it there. will use stereo headphones for output, (4-16 imped.) Any suggestions, or tips?
Need the following:
-Impedence of guitar pickup coils
-nominal pickup freq. range
-other then on/off, and volume, what tone controls might help?
Am considering using SMD to make it really small for him.
small guitar amp
:) hi there, you're just in time, i have just finished the small guitar amp for my son which he had the same problem as your friend. I used 2 LM386-1 for stereo output. it operates at 4 - 12v and i used 9v so if he brings it out to his friend a 9v batt will do. It has 3 inputs so that it could accomodate a CD player or a cassette player. all inputs as provide with its own volume control. no problem with the highs but with the lows its a bit inadequate as what my son said, so i added a bass boost circuit and that solve the problem. my pcb size is 1-1/2 x 2". if you need the circuit diagram, just email me. :D
small guitar amp
Mosikluz, I'd like to see your circuit also... can you post it here as an attachment? or your e-mail address?
Thanks!
sent circuit diagram of guitar amp
:D have you recieve the circuit diagram? :D
