I’m currently trying to plan out a project involving the output from a Gold Wafer PIC card. Basically what I want to do is have two lines from the card (CLK and DATA) interface to the clock and serial data inputs respectively of an 8-bit shift register (or two cascaded 4-bit registers) in a serial-in-parallel-out config. The parallel output of the shift register(s) would then be fed to two 4-into-16 decoders, one for the most significant 4 bits and one for the least. When the outputs of these decoders hit a certain value (e.g. 5 and 8 ) it would activate an AND gate attached to the appropriate outputs and thus light a led.
Basically all I need the gold wafer card to do is output a preset string of 8 bits in length and then stop, whilst outputting a clock signal on another line (unless an external clock is used), however I can’t find any info on how to interface one of these cards to an actual circuit, whether I need an external clock and if so how it should be connected etc.
There is a basic schematic of the card at **broken link removed**. It is based on a PIC 16F84/16F84A with the five wires needed for programming only.
Could anyone help with ideas of how to interface a card like this (for output, as well as for programming), links to existing schematics on the net or even help with how to output the required data from the PIC (although I’m probably asking in the wrong section of the forum for that last one)?
