Getting a 5Volt output from 12V with minimum losses
tytower
Banned
I have to take 12Volts from acar battery and power a device with no more than 5 volts fairly steadily. I have always thought 7805 regulators to be avery energy inefficient way of doing it due to the wasted heat generated .
I have assumed that those regulators behave as a 5V zenner diode where the excess voltage is just shunted to ground almost like a light which gets brighter the more energy goes to ground. Perhaps thats my answer to use that shunted voltage to do something .
So does anbody have any suggestions as to an efficient wayto get 5V ?
In a zener regulator it isn't excess voltage that is shunted to ground, it is excess current.
A zener regulator will take a constant current, usually a bit more than the maximum current that the load will take.
I think of it like a fixed valve filling a cistern with an overflow.
A series regulator like the 7805 blocks the excess voltage. The current it takes is about equal to the load current, and varies as the load current varies.
I think of it like a ball valve filling a cistern.
A buck converter can output more current than the input current. The no-load current is often a bit more than the no load current for a series regulator.
The choice of regulator type depends on how much current the load takes.
A simple buck converter will work well for you.
Here's a link another user here provided to me ages ago that should be a drop in replacement, depending on your current needs.
Complete circuit and component listing for a 14V to 5V regulated buck converter. A zener is used as a voltage refrence so it can actually be set to any desired output voltage in range.
2-transistor Black Regulator
If you want a quick easy solution, look at a Recom regulator.
I use loads of these, 26V In 5V Out @ 500mA max.
Jim
Thanks -things have changed . That RECOM device looks good . Now to see if I can get them in OZ
Phwew $15 each , I ordered 1
