Garage Door Opener Stalls
jpanhalt
Most Helpful Member
Brand: Moore 0' Matic (no longer in business)
Model: UltraLift
Age: >10 years
Lift mechanism: spring-assisted jack screw
I believe the motors are capacitor start, induction run, 115V AC, 60 Hz, USA. I do not/cannot see a centrifugal switch on the motors, but I have not taken them apart. The motor starts, lifts the door a foot or so, then stops or crawls to the fully open position. Springs are adjusted per instructions, so slight down pressure is required to close door. Condition worsens when it is cold (<0°C). Replaced the capacitor for one opener with no change in symptoms -- it was a cheap, quick test for what seemed like an unlikely cause.
Could the capacitor cut-out switch be a voltage controlled relay?
They stop about where they start to do lifting, so I am assuming running torque is bad. What is the most likely cause for that? Bad main winding? Failure to disengage starting capacitor? Other? Insufficient grease on the jack-screw does not seem to be the cause. I can also lift the doors manually with relative ease. The operators are old, so there are no child safety interlocks.
John
Have you tried operating the screw-jack by hand to check how freely it moves? Slight distortion or corrosion, or a failed bearing could cause excessive friction in the jack or, for that matter, in the motor itself.
Clean and relubricate the screw. The grease gets sticky when cold. Use the teflonized silicone spray.
No binding without load, but I went ahead and re-lubed each anyway. Now both work. It's a miracle. :o
Now I can get my airplane hauler out to go flying.
Thanks all.
John
