Fun with AI and swordfish basic
I'm slowly getting the hang of swordfish again forget AI writing code tho but its good at helping with structure
I got ws2812 working using arduino neoled coding ASM for timing
I'm going to make my led light controller using a pico i found them on small board for $4 each.
This code sends out the colors noth fancy but the dang timing is dead on
Device=18F25q10
Clock=64
Include "intosc.bas"
Include "utils.bas"
// alias to port pin...
Dim LED As PORTC.2
Dim Index As Word
Inline Sub onebit_delay()
 Asm
  BSF LATC, 2       ; Set data High
    NOP               ; ~62.5 ns each (assuming 16 MHz)
    NOP               ; Add enough To reach ~700 ns
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
  BCF LATC, 2       ; Set data Low
    NOP               ; Enough For ~600 ns Low
    NOP
    NOP
    NOP
    NOP
 End Asm
End Sub
Inline Sub obit_delay()
 Asm
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
    NOP
 End Asm
End Sub
SetAllDigital()
// main program...
Low(LED)
Index = 0
Repeat
Inc(Index)
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    'red    1
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    'green  2
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    obit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    onebit_delay
    'blue 3
Until Index > 60
If you want fancy the loops would have to be all done behind the scene in asm cause they take to long.
I'm still working on asm to load colors thats using calls for each bit green red blue
Here's me and AI shot at it
' --- Device Configuration ---
Device = 18F25Q10                     ' Target microcontroller device
Clock = 64                            ' System clock frequency in MHz (using 64 MHz internal oscillator for precise timing)
Config RSTOSC = HFINTOSC_64MHZ        ' Configure reset oscillator to internal HFINTOSC at 64 MHz (ensures MCU starts at 64 MHz)
' (Other config bits like WDT, LVP, etc., can be set as needed for your project)
' --- Include Libraries ---
Include "system.bas"                  ' System library (provides NOP, Delay routines, etc.)
'Include "intosc.bas"                ' Alternative: this library can auto-configure the internal oscillator (if available)
' --- Pin Definition ---
Dim WS2812BDataPin As PORTC.2         ' Data output pin for WS2812B LED strip (change if using a different pin or port)
' --- WS2812B LED Strip Parameters ---
Const NUM_LEDS As Byte = 20           ' Number of LEDs in the strip (modify if different)
Dim LED_Data(NUM_LEDS * 3) As Byte    ' LED color data buffer (3 bytes per LED for Green, Red, Blue)
' --- WS2812B Timing-critical Subroutines ---
' Subroutine to send a single byte to the WS2812B.
' This routine bit-bangs 8 bits with precise timing.
' At 64 MHz (16 MIPS, 62.5 ns per instruction), the NOPs produce the required pulse widths:
'  - For a "1" bit: ~0.8 µs HIGH and ~0.45 µs LOW (approx 12 NOPs high, 7 NOPs low).
'  - For a "0" bit: ~0.4 µs HIGH and ~0.85 µs LOW (approx 6 NOPs high, 13 NOPs low).
Sub SendByte(ByVal DataByte As Byte)
    Dim bitIndex As Byte
    For bitIndex = 0 To 7                ' Send 8 bits (MSB first)
        If DataByte.bits(7 - bitIndex) = 1 Then
            ' Send a "1" bit (data line high then low)
            WS2812BDataPin = 1          ' begin HIGH pulse for "1"
            nop                         ' ~62.5 ns
            nop                         ' ~125 ns
            nop                         ' ~187.5 ns
            nop                         ' ~250 ns
            nop                         ' ~312.5 ns
            nop                         ' ~375 ns
            nop                         ' ~437.5 ns
            nop                         ' ~500 ns
            nop                         ' ~562.5 ns
            nop                         ' ~625 ns
            nop                         ' ~687.5 ns
            nop                         ' ~750 ns (HIGH for ~0.75 µs)
            WS2812BDataPin = 0          ' end HIGH pulse, start LOW pulse
            nop                         ' ~62.5 ns
            nop                         ' ~125 ns
            nop                         ' ~187.5 ns
            nop                         ' ~250 ns
            nop                         ' ~312.5 ns
            nop                         ' ~375 ns
            nop                         ' ~437.5 ns (~0.44 µs LOW)
            ' (HIGH ~0.75 µs, LOW ~0.44 µs for "1" bit)
        Else
            ' Send a "0" bit (data line high then low)
            WS2812BDataPin = 1          ' begin HIGH pulse for "0"
            nop                         ' ~62.5 ns
            nop                         ' ~125 ns
            nop                         ' ~187.5 ns
            nop                         ' ~250 ns
            nop                         ' ~312.5 ns
            nop                         ' ~375 ns (~0.375 µs HIGH)
            nop                         ' ~62.5 ns
            nop                         ' ~125 ns
            nop                         ' ~187.5 ns
            nop                         ' ~250 ns
            nop                         ' ~312.5 ns
            nop                         ' ~375 ns
            nop                         ' ~437.5 ns
            nop                         ' ~500 ns
            nop                         ' ~562.5 ns
            nop                         ' ~625 ns
            nop                         ' ~687.5 ns
            nop                         ' ~750 ns
            nop                         ' ~812.5 ns (~0.813 µs LOW)
            ' (HIGH ~0.375 µs, LOW ~0.813 µs for "0" bit)
        End If
    Next
End Sub
' Subroutine to send one complete LED's color (3 bytes for Green, Red, Blue) to the strip.
' WS2812B LED expects data in GRB order.
Sub SendColor(ByVal Green As Byte, ByVal Red As Byte, ByVal Blue As Byte)
    SendByte(Green)    ' send Green component
    SendByte(Red)      ' send Red component
    SendByte(Blue)     ' send Blue component
End Sub
' Subroutine to push out the entire LED_Data buffer to the LED strip.
' This iterates over each LED's GRB values and uses SendColor to update them.
' After sending all data, it sends a reset/latch pulse by keeping data line LOW for >50 µs.
Sub ShowLEDs()
    Dim idx As Word
    For idx = 0 To (NUM_LEDS * 3 - 1) Step 3
        SendColor(LED_Data(idx), LED_Data(idx + 1), LED_Data(idx + 2))
    Next
    WS2812BDataPin = 0          ' ensure the data line is LOW
    DelayUS(60)                 ' hold LOW for at least 60 µs to latch data (reset pulse > 50 µs)
End Sub
' Subroutine to set the color of a specific LED in the LED_Data buffer.
' Parameters:
'    LED_Index - index of the LED (0-based)
'    Red, Green, Blue - 0-255 intensity values for each color channel.
' This does NOT immediately update the LED; it only updates the buffer.
Sub SetLEDColor(ByVal LED_Index As Byte, ByVal Red As Byte, ByVal Green As Byte, ByVal Blue As Byte)
    If LED_Index < NUM_LEDS Then        ' check bounds
        LED_Data(LED_Index * 3)     = Green   ' store Green component
        LED_Data(LED_Index * 3 + 1) = Red     ' store Red component
        LED_Data(LED_Index * 3 + 2) = Blue    ' store Blue component
    End If
End Sub
' --- Main Program ---
Dim i As Byte
Const BLINK_DELAY_MS As Word = 500     ' Delay time in milliseconds for blink intervals (adjust for faster/slower blink)
Low(WS2812BDataPin)                    ' Initialize the data pin to LOW and set it as output
' Initial LED setup: start with all LEDs off
For i = 0 To NUM_LEDS - 1
    SetLEDColor(i, 0, 0, 0)            ' set each LED color to off (R=0, G=0, B=0)
Next
ShowLEDs()                             ' send initial off state to all LEDs
DelayMS(100)                           ' small delay to ensure LEDs have latched off
' Now enter the blink loop: all LEDs will turn on, wait, then turn off, wait, repeatedly
While true
    ' 1. Turn all LEDs ON (set to a chosen color)
        ' Example: make all LEDs white. You can change the values for a different color.
        SetLEDColor(i, 255, 255, 255)  ' set each LED to White (Red=255, Green=255, Blue=255)
    Next
    ShowLEDs()                         ' output the "all ON" data to the LED strip
    DelayMS(BLINK_DELAY_MS)            ' keep LEDs on for BLINK_DELAY_MS (pause with LEDs lit)
    ' 2. Turn all LEDs OFF
        SetLEDColor(i, 0, 0, 0)        ' set each LED to off (black)
    Next
    ShowLEDs()                         ' output the "all OFF" data to turn off the LEDs
    DelayMS(BLINK_DELAY_MS)            ' delay with LEDs off before the next cycle
    ' The loop then repeats, causing the LEDs to blink on and off continuously.
Wend  ' (Alternatively, you can use "Loop" or another infinite loop mechanism in Swordfish Basic)
Again, post #22 has a faster send byte routine.
You'll have to adjust the low time to account for the looping and test, but it'll be closer
I figured out the deal I tried post 22 but I had Ai clean up and comment the code and look at it it removed the part that set the pins to digital output
Last night I found this out I’m about sure that’s why it looked bad with logic tool I couldn’t dial the nops in I was so busy trying to get timing write I never looked over the rest of the code
Now this would be some christmas lights mrdeb this with pico but i did it with a pic 18f25q10 too but i forgot to record it
