I found two links to a Harduino and one is not using the same setup as a arduino and one is a homemade board that needs a USB to tll upload cable.
Com port can be a problem It happens if you plug in to a different port with the ide open more then if you have the arduino plugged in the USB at start. And some of the arduinos don't handle bootloader mode right you have to press there button to get it into boot mode and one of those is tricky. You watch the ide and as soon as it tells you it's none compiling you press the button.
