Fax Machine LCD
TheNewGuy
Hello,
I have this LCD screen I pulled from a fax machine, and I am trying to identify it and see if I can connect it to a computer at all?
Thanks for the help,
-TheNewGuy
Are there no references? google them, try to get a datasheet, if it's a good datasheet, it should have everything, maybe even working code, as for connecting it to a computer, maybe a parallel port app should do, if not, have an MCU between the lcd and the computer.
props on the clear focused picture by the way!
Yeah, it is a good practice anytime to get datasheets, and the LCD would need some interfacing before you can connect it to a PC. Use PICs, they're simpler to control LCDs.
I can't find any numbers on it - maybe its one of those 'in-house' parts?
In this case all you can do is try to use it like its an HD44780 model? If it was still in the machine, you could reverse-engineer it.
And don't forget about AVRs now :)
I think it is one of those "in-house" parts. Because I can't find any sort of numbers on it whatsoever. I was hoping someone would recognise the shape of it and hopefully tell me how I could use the ribbons.
I still have the board that the ribbon plugs into. Should I grab my camera...
The board where the lcd plugs into
probably you can reverse engineer the pinouts by giving a 10-bit binary value from 0 to 1024, 'coz there are 10 pins there. You'll need MCUs for that.
Hmm...that sounds like an idea. It would be possible, but it sounds like it is harder than just getting a HD44780 or similar like Birdman suggested?
EDIT: But either way you have to get a microcontroller and programmer and learn C. Maby not for the novice?
Sparkfun has a great tut on learning C and using AVRs - he makes it easy! Now using the micros to reverse-engineer the communication, harder. Honestly, I would just buy an HD44780 LCD, or if you don't want to figure that out, buy a SerialLCD.
I might do that, how much do the programmers cost for the PIC? Is an AVR the same as a PIC?
Just buy a Matrix Orbital display.
Matrix Orbital Display...that sounds cool!
EDIT:Also, I pulled this from the Fax Machine also:
Woa, that Matrix Orbital Display is beautiful! :D
I had to stretch your picture out onto both my monitors to see it all at once, and I can't figure out that that part its! What part of the machine did it come out of? I'm thinking it was maybe a light-strip for scanning or faxing inside the machine.
AVRs and PICs are both micro-controllers. Both are very popular among engineers and hobbyists. The AVR family is made by the company Atmel. I've only ever worked with AVRs. PICs are a microcontroller family made my the company Microchip.
Here's an AtMega168:
Isn't it cute?
AVRs have a wonderful development platform called Arduino. They are $30.
I never use dev boards. Just the chip on a breadboard with all it's friends.
Here's the ultimate guide to first getting started with AVRs.
Beginning Embedded Electronics
The parallel port programmer for AVRs is $12 from Sparkfun.
OOPS, forgot to size it down. I was in a rush, posted it and left. :P I got it out of the part that scans the paper. I wonder if it can come to use?
Isn't it cute?
So it is a bit more novice friendly than I thought. Good way to learn C too also?
Either are good for C. If you really want, you you can also program them in BASIC. And if you really want, you can program in Assembly too. :eek:
So if it was near the area where it scans the paper, then I'm thinking it's either a light to illuminate the paper so the scanner can see it well, or it is actually the scanner part. I have no idea how to interface with something like that however.
The thing is, it has pins coming down the side of it as if it is an IC? :?
EDIT: Press CNTRL + F5 to refresh and the picture will become smaller
This a ccs sensor. Mostly old type scanners have of this ccs sensors. Sensors names writes behind of this sensors. You have to desolder to see the name. For lcd pin outs you need service manual of this fax machine or maybe something writing on the lcd board. code, name or so... I didnt see detail foto ot the lcd board. Maybe i could say something.
By the way, as far as the original LCD you were talking about that doesn't look like a 'module' at all, just a raw LCD display, the output pins are probably a multiplexed row/column setup for the individual elements of the LCD. It would have been easier to figure out what pin was what if you could have checked it with a multimeter or scope while it was still on. You could probably test it using a single AA battery connected to wire leads, and just start touching the pins the AA battery will provide the bias required by the LCD, though I don't think they like constant DC it's an easy way to test them. You'd have to be pretty determined to want to use that EXACT LCD from that fax machine in order to justify building an interface as I think the rest of this posts shows there are some really great modules out there that require nothing more complicated than a serial interface.
