Hey everybody, bit quiet in this section so thought I would try a post!
I have a 1Kw array on the roof made of four 60 cell 260W panels in series.
Recently the peak power available has dropped from around 1100W to 750W, so I cleaned them as this is usually the reason for a drop in peak power, however that didn't fix the problem, just raised the peak to around 850W (yup the were dirty) , so in desperation I got out the DVM!
ISC was still a very healthy 9.3A (spec 9.1A) but VOC had dropped from the specified 150V to around 136V.
More interestingly the MPPT controller was running them around Vmpp 108V instead of the normal (and specified) 120V.
These things are inaccessible big time being on the roof but I suspect a panel fault as a faulty controller would not affect VOC (IMOP).
I am thinking along the lines of a shadow diode gone short circuit, there being 3 strings of 20 cells in each panel so 12 strings in all and one diode short on the array would reduce the output voltage by 1/12th.
I don't think its a corroded tabbing wire (1st thought) as I couldn't see any substantial corrosion through binoculars and my guess is such a fault would affect ISC.
Does anyone here have any experience of array faults, do my symptoms sound familiar ????
