F84A simulation with MPLAB SIM 7.21
akg
Hello all
I'm a newbie the pic programming field ..i was just tring to test a piece of f84a code in the simulator to check its functions and so.. i found that i can change the values of register during the simulation..except for PORTA/B even if it in input mode.. is there any something wrong ?.How to simulate an input in the ports.. also bsf PORTA,0 also didn't set the bit.
Further ..i have got many ckts fro programming the PIC. and s/w also.. like JDm,AN589 ,Ic-proj,winpic etc..which is the best in ur opnion
Thanks in advance
Akg
In MPLAB there is a thing called "Input Stimulus" that allows you to simulate digital inputs. The PIN HAS to be in input mode to be setable/clearable from MPLAB, you can't use BCF/BSF instructions beacuse these are for setting/clearnig output pins, not input ones.
Question about Programmer SW and HW is hard and you will get many answers. I preffer JDM+Ic-prog for simplicity.
Although my first programmer is JDM, I would not recommend anyone to build it first because there are so many external factors that can make the JDM not working properly. People blame JDM but it is really factors like serial port current and voltage not being able to power the PIC properly.
My recommendation would be P16PRO40 with WinPicProg.
Possible limitations
Just in case, for whatever PIC you use, :idea: first check the limitations, basically, what is NOT simulated.
I don't know for that specific PIC but, could be your case :?:
