Extending laptop charger cord
chris414
The coaxial cable (3 wires) from my laptop charger to my laptop broke, and while fixing it I thought I may as well give it some more length (about 5 meters). Would there be any problems if I used 5 meters of normal power cable (3 wires running parallel to one another) to lengthen the coaxial cable?
dont want to break my laptop or anything:S i read somewhere that if you dont use coaxial cable there's interference or something so you dont get a smooth power supply... is this anything to worry about? what's the worst that could happen?
The main reason for the coaxial cable is probably to prevent the laptop from interfering with nearby radio receivers. Unshielded cable increases the risk that some nearby radio receivers will pick up unwanted noise.
If you extend it with wire that's too thin it will take longer to charge.
