EUSART issues
richb
Hi Guys, i'm banging my head against a brick wall at the moment, if anyone can take a quick look over the code, it would be most appreciated.
I'm using the PIC18f4580 and trying to simply transmit rs232 to my computer via hyperterminal using the max233. When i compile the code on my 16f877a it works fine (ob altering the SPBRG setting), but on the 18f, i have no luck.
Here is my code:
#include <pic18f4580.h>
void putch(unsigned char c)
	while(!TXIF) continue;	// set when register is empty
	TXREG = c;
void puts(const char *str)
	while(*str){
		putch(*str);
		str++;
void rs232_init()			// Sets USART to 9600 Baud, 8-bit data
	SPBRG =	51;
	BRGH =	1;
	BRG16	= 0;				//
	SYNC =	0;				// Asynch Operation
	SPEN =	1;				// Enable Serial Port
	CREN =	1;				// Enable Reception
	TXEN =	1; 				// Enable transmission & Set TXIF
	TX9  =	0;				// 8- or 9-bit transmission
	RX9  =	0;				// 8- or 9-bit reception
	RCIE =	1;
void main(void)
	IRCF2		= 1;
	IRCF1		= 1;
	IRCF0		= 1;
	/*disable comparator module*/
	CM0	= 1;
	CM1	= 1;
        CM2 = 1;
	/*Disable PSP (parallel slave port) */
	PSPMODE = 0;
	PCFG3	= 1;
	PCFG2	= 1;
	PCFG1	= 1;
	PCFG0	= 1;
	LATD	= 0xFF;
	LATE	= 0x00;
	TRISD 	= 0x00;
	TRISA	= 0xFF;
	TRISE	= 0x00;
	TRISC6	= 0;
	TRISC7	= 1;
	rs232_init();
	puts("move forward!!");
I am running the pic at 8mhz using the internal osc (i hope) although don't have any available scope to check this.
Any help would be greatly appreciated
Cheers
Richb
hi
had a look at the datasheet again,
TRISC<6> must be cleared (= 0) for
Asynchronous and Synchronous Master modes,
or set (= 1) for Synchronous Slave mode
from memory i believe i want to set the device as a master, although i could be wrong.
I did try setting it to 1, but no luck i'm afriad.
Oops.. What I've stated earlier is not applicable for your PIC :)
Try to wait IOFS to be set to make sure that the internal oscillator is stable in order to get UART to work properly. See whether it helps or not.
