Equivalent to BAT42
Hero.sl
Hello guyz..
I'm trying to build the PIC programmer listed in the following site
(PIC Programmer for Windows - Help Index) to program my PIC16F628A MCU. The diode, BAT42 is not available in the local market(I'm from Sri Lanka) and it is useless to order few diodes online(well thy don't allow). Could someone plz tell me an equivalent diode for BAT42 to use in the above circuit? Thanks.
ps. I saw few posts about the "Blue Room Electronics" Programmer. But I cant view that site.. dunno why :(
Hello guyz..
This is the datasheet for the BAT42, you require a low turn on voltage Schottky diode.
Thanks Eric. I got the datasheet. Could you please suggest a diode? I'm not an expert in electronics, so I guess it will be good to ask it from you. :D Thanks
Have looked, they are the BAT series.
I'll look at the circuit.
Rectifier - Schottky | Farnell UK
EDIT:
the circuit is using these BAT42's as clamping diodes for the RS232 lines into the PIC. It recommend a diode with<=500mVfwd.
Can you get BAT85's.?
Did you see the note regarding the unreliabilty of this prommer.!
The BAT42s aren't required. The Pics internal clamping diodes do the same job. The version with the external power supply is actually very good, I used it for many years before I got an ICD2 without problems.
P.S. This is the circuit I'm referring to,
Note, both the 12V and 5V supplies are not generated from the RS232 connection.
I don't think I will be able to see a BAT diode unless I go abroad. :D
Ya I was also not sure about the circuit. But now Mike confirmed that the circuit is working. So I'll forget the clamping diodes and continue..
Thanks a lot (Y)
EDIT:
Do I have to connect Pin 12 or Pin 13 with Pin 14 when the diodes are removed?
and Pin 14 should be connected with only 1k Resistor,Capacitor and Zener?
(sorry for off topic)
Just remove the diodes. There is no need to connect any pins together.
