RoboWanabe
Hi There
Could one of you kind sirs please help me.
BackGround
I'm trying to Fix my nephews scooter, which after charging the recommended amount of time (8hr), seems to be loosing charge within 10 minutes of use.
The problem I think is that my sister has got the charger mixed up and has been using the wrong one, but i'm not to sure about batteries and charging so could do with some help please.
Information
The battery is:
SEALED LEAD-ACID BATTERY
CB4.5-12 (13v4.5AH/20HR)
CONSTANT VOLTAGE CHARGE
Cycle Use = 14.0-15.0v 77F(25c)
Standy Use = 13.5-13.8v 77F(25c)
Initial Current: Less than 1.35A
The charger is:
Model:HGIL240040 ( Was blured when reading this could be wrong)
Input:AC 230v -5hz 18w
Output
C 24v 400ma
Finally
Could someone please tell me if we are using the right charge? my guess is not. I cant see why you would need 24v to charge a 12v battery.
And Could any one please give an explanation on what some of the terms above mean (e.g. cycle use, standby use, inital current).
What is the general rule or method of charging a battery? can you point me to a good tutorial?
Thanks you so much for your help
BackGround
Information
The battery is:
The charger is:
Output
Finally
