Electric Car Instrumentation
Chappie
I'm currently designing the instrumentation for an electric car i.e. ammeter, voltmeter, motor temp indicator etc. I've chosen a PIC to monitor all analogue I/p's and display the results on several 7-seg disp. However, I'm having trouble using multiple lookup tables for the various I/p's.
First I thought of checking the analogue ch bits and jumping to the relevant subroutine from there...but it isn't working. :confused: Any I/p would be gratefully recieved
I'm using a 16f877A PIC btw.
Sorry. Hope this helps make it a little clearer
;The ch0 A/D result is displayed as a 8 bit value
;and subsequently converted to BCD
;Hardware: PICDEMO board.
	LIST P=16F877A
        ERRORLEVEL  -302
	include "p16F877A.inc"
TEMP    EQU     20h
adif    equ     1
adgo    equ     2
ch2     equ     6
ch3     equ     7
ADTABLE equ     20
	ORG     0x00
	goto    start
	org     0x04
	goto    service_int     ;interrupt vector
	org     0x10
start
	movlw   B'00000000'     ;make port b
	movwf   PORTB          	;all outputs
;	tris    PORTB          	;       /
        BSF     STATUS, RP0     ;Bank1
        MOVWF   TRISB           ;PortB as outputs
        BCF     STATUS, RP0     ;Bank0
	call    InitializeAD
update
	movf    ADRES,W
	movwf   0               ;save in table
	movlw   ADTABLE         ;chk if ch0
	subwf   FSR,W           ;     /
	btfss   STATUS,Z        ;yes then skip
	goto    NextAd          ;else do next channel
	movf    ADRES,W         ;get a/d value
	call	outputdata    	;call correct lookup table
	movwf   PORTB		;output to port b
NextAd
	call    NextChannel     ;select next channel
	call    SetupDelay      ;set up > = 10uS
	bcf     ADCON0,adif     ;clear flag
	bsf     ADCON0,adgo     ;start new a/d conversion
loop
	btfsc   ADCON0,adif     ;a/d done?
	goto    update          ;yes then update
	goto    loop            ;wait till done
service_int
	return                  ;do not enable int
;InitializeAD, initializes and sets up the A/D hardware.
InitializeAD
	bsf     STATUS,5        ;select Bank1
	movlw   B'00000010'     ;Vref+ is Vdd, Vref- is Vss, AN0-AN3..
	movwf   ADCON1          ;analog inputs
	bcf     STATUS,5        ;select Bank0
	movlw   B'11000001'     ;select:internal RC, ch0, ststus flag off..
	movwf   ADCON0          ;turn on a/d
	movlw   ADTABLE         ;get top of table address
	movwf   FSR             ;load into indirect reg
	clrf    ADRES           ;clr result reg.
	return
;NextChannel, selects the next channel to be sampled in a
;"round-robin" format.
NextChannel
	movlw   0x08            ;get channel offset
	addwf   ADCON0, F       ;add to conf. reg
	bcf     ADCON0,5        ;clear any carry over
;increment pointer to correct a/d result register
	clrf    TEMP
	btfsc   ADCON0,3        ;test lsb of chnl select
	bsf     TEMP,0          ;set if ch1 or ch3
	btfsc   ADCON0,4        ;test msb bit of chnl select
	bsf     TEMP,1          ;set if ch0 or ch2
	addwf   TEMP,W          ;add with temp
	movwf   FSR             ;allocate new address
	return
;This routine is a software delay of 10uS for the a/d setup.
;At 4Mhz clock, the loop takes 3uS, so initialize TEMp with
;a value of 3 to give 9uS, plus the move etc should result in
;a total time of > 10uS.
SetupDelay
	movlw   .3
	movwf   TEMP
SD
	decfsz  TEMP, F
	goto    SD
	return
outputdata
I would like to know how I can refer to different lookup tables for AN0-AN3...
Simply don't run it in a single loop, read each input in turn, display it as required, then move to the next input and do the same - enclose the complete chain in an overall loop.
