Atomic_Sheep
Hello,
I'm building a RC model and I'm trying to put an electronic limiter on the servos to prevent them from moving past certain points.
The battery pack that I'm using on the model is 1.2V x 4 (4.V 600mAh). I am not sure how much of this voltage actually goes through to the servos, the battery pack is connected to the receiver which is then connected to the servos. Perhaps there is a bus inside the receiver which provides power for the receiver and the servos in parallel but I have no idea. I don't have an oscillascope either, so please bare this in mind.
Obviously, we would be inserting some sort of electronics circuit between the receiver and the servos given what I described above.
For those who are unfamiliar with RC servos, the servo position/angle is dictated by pulse width. I'm not sure, but I have a feeling the period of the pulses doesn't change, just the pulse width although I'm sure this isn't universal. Anyway, lets take 1.5ms as the pulse width for the middle position. Anything for example over 2ms I want to prevent i.e. I want to force the voltage to 0 when signals go above 2ms in pulse width and below 1ms I want to 'boost' the signal for an additional period of 1.0-x.
Baring in mind that only the original battery pack can be used as a source of power for this circuit, can anyone suggest anything to solve this problem?
