DTMF Circuit needing immdiate help
TechINT
Hello all,
I am trying to program a circuit using DTMF technology. This is my first attempt at programming but I do have an electronics background.
I am running into multiple problems. I am trying to fix one problem at a time. My current problem is my timer issue.
My timer code does not appear to be working properly. When I enter 6 (my DTMF tone generator), instead of my timer functioning, the STA (Safe To Arm) begins once again.
My code is below. I would appreciate any and all help with this project. I am under a deadline which is days away and I am far from finishing. My circuit is the attachment.
'* Name : TIMER, CMD, STA v2.BAS *
'* Author : [select VIEW...EDITOR OPTIONS] *
'* Notice : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 11/21/2012 *
'* Version : 1.0 *
'* Notes : *
CMCON = 7 ; TURNS OFF COMPARATORS (PORTA.2, .3, & .4)
TRISA = %10001111 ; SET PORTA.0-.3 AND .7 TO INPUTS, REST TO OUTPUTS
TRISB = %11100001 ; SET PORTB.0, .5, .6, .7 TO INPUTS, REST TO OUTPUTS
CODEIN VAR BYTE
ACTIVATIONCODE CON $01
DET CON $04
TIMERSTART CON $06
TIMERSTOP CON $07
X VAR BYTE
TIMERCOUNT VAR WORD
PORTB.3 = 0
STA: ; SAFE TO ARM
PORTB.4 = 0 ; ENSURE OUTPUT TO LOAD IS LOW
PORTB.5 = 0 ; ENSURE LOAD LED INDICATOR IS LOW
PORTA.6 = 0 ; ENSURE BUZZER IS OFF
FOR X = 1 TO 20 ; 10 SEC STA W/ BLINKING LED
TOGGLE PORTB.3
PAUSE 500
NEXT X
START:
PORTB.3 = 1 ; SAFE TO ARM HAS EXPIRED SO LED STAYS ON
TIMERCOUNT = 0 ; RESET TIMER COUNTER
IF PORTB.0 = 0 THEN START ; WAIT FOR DTMF CODE
CODEIN = PORTA & $0F ; STORE INPUT FROM PORTA.0-.3
IF CODEIN = $05 THEN sta
IF CODEIN <> ACTIVATIONCODE THEN START ; WAITING TO RECEIVE VALIDE 1ST DIGIT
FOR X = 1 TO 20 ; IF YOU GET HERE, YOU ENTERED CORRECT ACTIVATION CODE
TOGGLE PORTB.3 ; LED FLASHES FAST FOR 2 SECONDS SO YOU KNOW
PAUSE 100 ; THE CORRECT ACTIVATION CODE WAS RECEIVED
NEXT X
PORTB.3 = 1
STDOFF3:
PAUSE 100
IF PORTB.0 = 1 THEN STDOFF3 ; WAITING FOR TONE TO STOP
COMMANDS:
if PORTB.0 = 0 THEN COMMANDS ; WAITING FOR NEW TONE
IF CODEIN = $05 THEN STA
IF CODEIN = DET THEN BANG
IF CODEIN = TIMERSTART THEN TIMER
FOR x = 1 TO 20 ; INVALID COMMAND TONE RECEIVED
TOGGLE PORTB.3
PAUSE 250
NEXT X
PORTB.3 = 1
GOTO COMMANDS ; GO BACK TO COMMAND INPUT AND TRY AGAIN (DEVICE STILL ACTIVE)
TIMER: ; 10 SECOND TIMER
IF PORTB.0 = 1 THEN TIMER ; WAIT FOR TONE TO STOP
WHILE PORTB.0 = 0 ; WHILE THERE IS NO TONE
PORTB.3 = 0
PAUSE 100
PORTB.3 = 1
PAUSE 900
IF TIMERCOUNT = 10 THEN BANG
TIMERCOUNT = TIMERCOUNT + 1
WEND
CODEIN = PORTA & $0F ; A TONE WAS DETECTED - STORE IT
if codein = TIMERSTOP THEN GOTO START
GOTO TIMER ; INVALID CMD, CONTINUE COUNTING
BANG:
PORTB.4 = 1 ; OUTPUT TO LOAD
PORTB.5 = 1 ; LED INDICATOR
PORTA.6 = 1 ; BUZZER
PAUSE 5000
GOTO STA
END
I didn't check your schematic as it is not a GIF or JPG, but one good idea is to put 4 LEDs on the 4 outputs fromt he DTMF decoder IC. Then when applying a tone you can see that the decoder has correctly sent out the right 4bit number.
