DS1337 Wierd Problem
AtomSoft
I am using a DS1337 (Not the C version) and every time it the minutes reach over 39 (so 40) it changes to 00. I know its the chip and not my code because i never write to the DS1337 unless its to set time which is done by buttons. Any thoughts? Faulty chip perhaps?
So my issue is i set the time to 7:45 and it changes itself to 7:05.
If i set to 7:38 its ok. Works fine untill it hits 39 where it jitters then 40 changes to 00. Any thoughts?
Here is my code.. (sorry not enough comments)
#include <p18f452.h>
#include <stdio.h>
#include "delay.h"
#include <spi.h>
//#include "sw_i2c.h"
#pragma config WDT = OFF, LVP = OFF, OSC = HS
#define SDA_PORT PORTBbits.RB0
#define SDA LATBbits.LATB0
#define SDA_TRIS TRISBbits.TRISB0
#define SCL LATBbits.LATB1
#define CS LATDbits.LATD0
#define Dots LATDbits.LATD1
#define dwnBtn PORTBbits.RB3
#define upBtn PORTBbits.RB4
#define entBtn PORTBbits.RB5
char slave_r = 0b11010001;
char slave_w = 0b11010000;
//TIME
char sec_h, sec_l;
char min_h, min_l;
char hour_h, hour_l;
char t_temp;
//Set Time
char setBtn;
void main(void);
void Init(void);
void WriteWord(char address,char data);
unsigned char WriteSPI(unsigned char data);
char rtc_write(char offset, char data);
char rtc_read(char offset);
void i2c_byte(char addr);
void i2c_start(void);
void i2c_ack(void);
char i2c_input(void);
void i2c_clock(void);
void i2c_stop(void);
void time_isr(void);
void button(void);
void setIt(void);
#pragma code high_vector_section=0x8
void high_vector (void)
_asm GOTO button _endasm
#pragma interrupt button
void button (void)
    INTCON3bits.INT2IF = 0;
    delay_ms(150);
    setBtn = 1;
void setIt(void){
    unsigned char done = 0;
    unsigned char minhour = 0;
    unsigned char hours, minutes, t_temp = 0;
    setBtn = 0;
while(!done){
Dots = 0;
    if(dwnBtn){
        if(minhour == 0){
            minutes--;
            if (minutes > 59)
                minutes = 0;
        } else {
            hours--;
            if (hours > 12)
                hours = 0;
        delay_ms(99);
    if(upBtn){
        if(minhour == 0){
            minutes++;
            if (minutes > 59)
                minutes = 0;
        } else {
            hours++;
            if (hours > 12)
                hours = 0;
        delay_ms(99);
        t_temp = minutes;
        min_h = t_temp / 10;
        min_l = t_temp - (min_h * 10);
        t_temp = hours;
        hour_h = t_temp / 10;
        hour_l = t_temp - (hour_h * 10);
        WriteWord(0x04,min_l);
        WriteWord(0x03,min_h);
        WriteWord(0x02,hour_l);
        WriteWord(0x01,hour_h);
   if(entBtn){
         delay_ms(99);
        if(minhour == 0){
            done = 0;
            minhour = 1;
        } else {
            done = 1;
         delay_ms(99);
    rtc_write(0x00,0x00);
    delay_ms(50);
    minutes = min_h;
    minutes = minutes << 4;
    minutes = minutes | min_l;
    rtc_write(0x01,minutes);
    delay_ms(50);
    hours = hour_h;
    hours = hours << 4;
    hours = hours | hour_l;
    hours = hours | 0b01000000;
    rtc_write(0x02,hours);
    delay_ms(200);
    Dots = 1;
void main(void){
    char x,y,z,i;
    Init();
   // rtc_write(0x0E,0x1B);
    while(1){
        delay_ms(100);
        t_temp = rtc_read(0x01);
        min_l = t_temp << 4;
        min_l = min_l >> 4;
        min_h = t_temp << 2;
        min_h = min_h >> 6;
        delay_ms(100);
        t_temp = rtc_read(0x02);
        hour_l = t_temp << 4;
        hour_l = hour_l >> 4;
        hour_h = t_temp << 3;
        hour_h = hour_h >> 7;
        if(setBtn == 1)
            setIt();
void Init(void){
    TRISA = 0;
    TRISB = 0;
    TRISC = 0;
    TRISD = 0;
    ADCON1 = 0x0F;
    TRISB = 0x00;
    TRISC = 0x10;               //SDO(RC5),SCL/SCK(RC3),CS(RC2) = Output, SDA/SDI(RC4) = Input
//Button
    TRISB = 0b00111100;
    PORTB = 0;
    LATB = 0;
    RCONbits.IPEN = 1;
    PIR1 = 0;
    INTCON3bits.INT2IE = 1;
    INTCONbits.GIEH = 1;
    INTCONbits.GIEL = 1;
    CS = 1;                     // Chip Select = OFF (Logic Low = Selected)
    OpenSPI(SPI_FOSC_4,MODE_11,SMPEND);
    WriteWord(0x0C,0x01);
    WriteWord(0x09,0x0F);
    WriteWord(0x0A,0x0D);
    WriteWord(0x0B,0x04);
    WriteWord(0x0F,0x00);
    Dots = 1;
void WriteWord(char address,char data){
    int x;
    CS = 0;                 //Select the chip
    WriteSPI(address);      //Buffer Write
    WriteSPI(data);      //Buffer Write
    CS = 1;                 //DeSelect the Chip
////            I2C FUNCTIONS
    SCL = 1;
    delay_us(5);
    SCL = 0;
void i2c_start(void){
    SDA_TRIS=0;   //SDA Output
    SCL=0;        //Clock Low
//Start - 5us
    SDA=1;        //SDA High
    SCL=1;        //Clock high
    delay_us(4);
    SDA=0;        //SDA Low
    delay_us(1);
    SCL=0;        //Clock Low
void i2c_byte(char addr){
    char bl;
    for(bl=0;bl<8;bl++){
        if((addr & 0x80) != 0)
            SDA = 1;
        else
            SDA = 0;
    i2c_clock();
    addr=addr<<1;
void i2c_ack(void){
    SDA_TRIS = 1;   //SDA Input
    i2c_clock();
    delay_us(5);
    //while(SDA);
    SDA_TRIS = 0;
char i2c_input(void){
    char temp;
    char i;
    SDA_TRIS = 1;
    temp=0;
    i = 0;
    for(i=0;i<8;i++){
        temp=temp<<1;
        if(SDA_PORT)
            temp|=1;
        i2c_clock();
    SDA_TRIS = 0;
    return temp;
void i2c_stop(void){
    SDA = 0;
    SCL = 1;
    delay_us(3);
    SDA = 1;
    SCL = 0;
////            RTC FUNCTIONS
char rtc_write(char offset, char data){
    char temp;
    i2c_start();                //Start
    i2c_byte(slave_w);          //Slave Byte
    i2c_ack();                  //ACK
    i2c_byte(offset);           //Address Offset
    i2c_ack();                  //ACK
    i2c_byte(data);          //Slave Byte
    i2c_ack();                  //ACK
    i2c_stop;                    //Stop
    return temp;
char rtc_read(char offset){
    char temp;
    i2c_ack();                  //ACK
    i2c_ack();                  //ACK
    i2c_byte(slave_r);          //Slave Byte
    i2c_ack();                  //ACK
    temp = i2c_input();         //Get Data
    i2c_ack();                  //ACK
    i2c_stop;                    //Stop
    return temp;
Is it possible you have one of the alarms set and the interrupt is somehow causing a reset. If you look at the alarm registers one of the modes is alarm when minutes match.
Looking at the pinout, a solder bridge between pins 7 & 8 could cause a reset when an alarm happens.
THANKS! you made me think more lol i found the issue:
BAD:
        min_h = min_h >> 6;
FIX:
        min_h = t_temp << 1;
        min_h = min_h >> 5;
Wow this sucks. I set the time to match my cable box time. When i woke up today it was about 40 minutes ahead of my cable time. So i reset the clock to 7:30AM to match my cable time and not its 8AM but my clock says its 8:02AM. Any thoughts on the timing issue?
Mine keeps perfect time. Are you sure your crystal is the right type and has the correct capacitors? Can you post a schematic?
i dont have a schematic. Am i supposed to have caps on the crystal ?
Page 6 of the DS1337 Datasheet:
"The DS1337 uses an external 32.768kHz crystal. The oscillator circuit does not require any external resistors or capacitors to operate. Table 1 specifies several crystal parameters for the external crystal."
I used:
32.768kHz crystal - dipmicro electronics
Sorry, I cant help you with you problem, but would like to say congrats on your clock, I like the way your LEDs are - using multiples for each segment. I imagine that once its boxed up it will have an cool 'old skool' look. :D
:D yeah that was the goal but i wanted it flat so i can put it on the wall. I will make a black enclosure for it with a faded white window for the time. (not sure if its called fogged plastic)
Loading...
[embed]http://www.youtube.com/v/b3Zzcg_10KI[/embed]
I understood there were 6pf and 12pf type 32768 Hz crystals. Does your DS1337 Data Sheet specify a crystal capacitance? Could the timing be affected by using a crystal with the wrong load capacitance?
Mike
<added>
Data Sheet says to use a 6pf crystal...
how would i measure my crystal ? I dont have a datasheet for it or really info on it. The only lettering on it is:
K0S50 or KDS50 or K0S5D or KDS5D
well it looks like the picture in my previous post.
The crystals I order from Mouser or DigiKey list the load capacitance. I'm not sure what you got from that source...
Regards, Mike
