Driving Multiple LED's - Problem
SpecialAgentBob
Hello everyone!
Glad to see such a supportive site for electronics.
I have a quick, most likely extremely simple question that I'm having a difficult time. Currently, I'm programming a circuit to drive a "sequence" of LEDs (with two designed to be on at one time), however, when I apply power to both LEDs, the second one to go high in the code will turn off the first one.
The code seems to work if I simply turn the entire PORTC on, such as with PORTC = 0xff. However, sending individual commands with RB6, RB7, and RB3 will only allow for one LED to be powered at once.
For example:
RC6 = 1; // LED 1
RC7 = 1; // LED 2
The code above will only make RC7 go high.
I apologize in advanced if this subject has been touched on, or if it is stated directly in the datasheet. I have tried searching, with no luck so far.
Appreciate the help in advanced.
Michael
SpecialAgentBob,
Which pic are you using - and what is the exact code that you are suing to set the pins?
Have a look on your data-sheet for read-modify-write. If you change a pin it will read the port, modify the bit & write the port. If you have not configured the port correctly (turn off comparators etc) the will always read beck as 0 (zero). :)
Thanks for such a prompt response! :)
Here is the code:
#include <pic.h>
#include <delay.h>
void main(void)
#define LED_OPEN TRISC6
#define LED_LOCKED TRISC7
#define LED_CLOSE TRISC3
#define SW_DIR TRISB7
#define SW_LOCKED TRISB6
#define IN 1
#define OUT 0
#define LED_OPEN_PIN RC6
#define LED_LOCKED_PIN RC7
#define LED_CLOSE_PIN RC3
#define SW_PIN RB7
#define SW_LOCKED_PIN RB6
   while(1)	// continually
		RBPU = 0;		// enable internal pullups on PORTB
		LED_OPEN = OUT;
		LED_LOCKED = OUT;
		LED_CLOSE = OUT;
		SW_DIR = IN;
		SW_LOCKED = IN;
		if(SW_PIN == 1 && SW_LOCKED_PIN == 0)
			// Then open the door
			// First illuminate lock
			LED_LOCKED_PIN = 1;
			DelayMs(100);
			// Now open the door
			LED_OPEN_PIN = 1;
			DelayMs(2000);
			LED_OPEN_PIN = 0;
			DelayMs(100);
			LED_LOCKED_PIN = 0;
			while(1)
				// Door open
				if(SW_PIN == 1)
					// Door close
					LED_LOCKED_PIN = 1;
					DelayMs(100);
					// Now close the door
					LED_CLOSE_PIN = 1;
					DelayMs(2000);
					LED_CLOSE_PIN = 0;
					DelayMs(100);
					LED_LOCKED_PIN = 0;
					break;
		else if(SW_LOCKED_PIN == 1)
			LED_LOCKED_PIN = 1;
		else
			LED_LOCKED_PIN = 0;
			LED_OPEN_PIN = 0;
			LED_CLOSE_PIN = 0;
This is being compiled in MPLAB, and programmed onto a PIC16F690. After reviewing the datasheet, I do not feel as if the comparator is causing the problem - though I don't understand much about it. ;)
As for the read-write-modify possibility, I never knew that could cause a problem! However, the delays in my code after the pins go high separate out the read-write-modify process, meaning the modify is taking place way in front of the next read, correct?
Thanks for the help!
Michael
Have a look at the data-sheet - top of page 76 (Port C config.) ANSEL & ANSELHI need to be configured or ports will read 0. CMCON also needs to be set.
Try adding to start of code:
CMCON0 = 7 //set digital I/O
ANSEL = 0 //
