Came across this at work .......
There are a bunch of Siemens 3 phase thyristor modules being driven by a 200Hz PWM @ 24V.
The thyristor modules seem pretty simple - put 24v on and it will turn on the three phases when they zero cross. Remove the 24v and they turn off.
Now ........ surely trying to drive them with an unsynchronised 200Hz PWM is going to cause phasing issues ? The PWM is run through a PID loop to control heater temperatures but say for example we have a 10% duty perfectly synchronised with our 50Hz mains, the start of the PWM pulse will be at the zero crossing point of the 50Hz mains therefore will never turn off.
If the PWM frequency was (for example) not exactly 200Hz, i.e. 200.0001Hz, we could be in a situation where you'd get a phasing effect and the output would turn on and off only when both the PWM and the mains frequency were within a certain part of the phase.
Your thoughts ?
Your thoughts ?
