distortion in inverting opamp
BkraM
Hi all,
I've build a basic inverting opamp circuit where I'm using a single power supply.
An artificial ground is created by a resistance divider.
similar to this image:
with R1 = 1k, R2=2k R3=R4=10k
I'm using a LM324 and a 7V source.
The result I get is that each time the input signal crosses the artificial ground level, there is a (small) distortion on the output:
red=input, blue = output
What is causing this distortion?
Thanks,
It´s called crossover distortion, and it is caused by that lousy 40 years old LM741. Either use something more modern, or add a resistor from the output to one of the supply rails, which will bias the output stage into class A instead of class B.
The other problem is that a '741 is very marginal at a single-supply Vcc of only 7V.
Which you might have realized if you had read the '741 datasheet, for which no values are even given for any supply voltage lower than 20V.
I was originally using a LM324, but i guess that did't make much difference
The LM324 and LM358 are notorious for that type of cross-over distortion. You can sort-of cure it by putting a 4.7K pull-up resistor between the the output pin of a '324 or '358 to its Vdd pin.
It is a shame that your schematic is wrong because it shows a 741 opamp that does not have crossover distortion but you used an LM324 that has 4 of the same opamps in an LM358 that do have crossover distortion.
The tutorial did not say why the LM324 and LM358 are designed to have crossover distortion. It is because these opamps are the first LOW POWER opamps so the output transistors do not have enough bias current (Class-B) so that the idle current very low which produces crossover distortion. All opamps that do not have crossover distortion have some bias current in the output transistors (class-AB).
With a single supply the crossover distortion load resistor must go to V/2 , so when a cheap LM324 is needed for high volume production and/or Very Low Supply Current Drain (700 μA), the fix is a pullup and pull down resistor which is effectively V/2. The external load current affects the base current which affects NPN/PNP bias Voltage towards eliminating the crossover distortion.
A pair in the range of 10k to 25k , as I recall, works well.
Using a pullup only also works but requires twice as much current and effectively puts the lower of the push-pull drivers into class A mode.
