'Fuses definition.
#define CONFIG1L = 0x00
#define CONFIG1H = 0x38
#define CONFIG2L = 0x1E
#define CONFIG2H = 0x3C
#define CONFIG3L = 0x00
#define CONFIG3H = 0x3D
#define CONFIG4L = 0x80
#define CONFIG4H = 0x00
#define CONFIG5L = 0x0F
#define CONFIG5H = 0xC0
#define CONFIG6L = 0x0F
#define CONFIG6H = 0xE0
#define CONFIG7L = 0x0F
#define CONFIG7H = 0x40
#define CLOCK_FREQUENCY = 64 'Clock 64Mhz
#define STRING_MAX_LENGTH = 60
'#define SIMULATION_WAITMS_VALUE = 1
'lcd driver
Const ILI9341_NOP = 0x00
Const ILI9341_SWRESET = 0x01
Const ILI9341_RDDID = 0x04
Const ILI9341_RDDST = 0x09
Const ILI9341_SLPIN = 0x10
Const ILI9341_SLPOUT = 0x11
Const ILI9341_PTLON = 0x12
Const ILI9341_NORON = 0x13
Const ILI9341_INVOFF = 0x20
Const ILI9341_INVON = 0x21
Const ILI9341_DISPOFF = 0x28
Const ILI9341_DISPON = 0x29
Const ILI9341_CASET = 0x2a
Const ILI9341_RASET = 0x2b
Const ILI9341_RAMWR = 0x2c
Const ILI9341_RAMRD = 0x2e
Const ILI9341_PTLAR = 0x30
Const ILI9341_COLMOD = 0x3a
Const ILI9341_MADCTL = 0x36
Const ILI9341_DISP_FUNC = 0xB6
Const ILI9341_MADCTL_MY = 0x80
Const ILI9341_MADCTL_MX = 0x40
Const ILI9341_MADCTL_MV = 0x20
Const ILI9341_MADCTL_ML = 0x10
Const ILI9341_MADCTL_RGB = 0x00
Const ILI9341_RDID1 = 0xda
Const ILI9341_RDID2 = 0xdb
Const ILI9341_RDID3 = 0xdc
Const ILI9341_RDID4 = 0xdd
Const LCD_BLACK = 0x0000
Const LCD_RED = 0x001f
Const LCD_BLUE = 0xf800
Const LCD_GREEN = 0x07E0
Const LCD_YELLOW = 0x07ff
Const LCD_MAGENTA = 0xf81f
Const LCD_CYAN = 0xffe0
Const LCD_WHITE = 0xffff
Dim LCD_width As Word ///< Display width as modified by current rotation
Dim LCD_height As Word ///< Display height as modified by current rotation
Dim LCD_rotation As Byte ///< Display rotation (0 thru 3)
Symbol TFT_RST = PORTC.0 'RST RESET pin
Symbol TFT_DC = PORTC.1 'DC (SS) Data/Command pin
Symbol TFT_CS = PORTC.2 'CS Chip Select pin
Symbol TFT_SCK = PORTC.3 'SCK as output
Symbol TFT_SDI = PORTC.4 'SDI as input -> SDO
Symbol TFT_SDO = PORTC.5 'SDO as output -> SDI
Dim x As Byte
OSCCON = 0x70
OSCTUNE.PLLEN = 1
TRISA.1 = 0
TRISC = 0
ADCON1 = 15
Call SPI_init()
Call LCD_init()
Main:
x = 1
While x = 1
WaitMs 300
LATA.1 = 1
Call fillScreen(LCD_RED)
WaitMs 300
LATA.1 = 0
Call fillwindow(10,10,310,230, LCD_BLUE)
WaitMs 300
LATA.1 = 1
Call fillwindow(10,10,310,230, LCD_GREEN)
WaitMs 300
LATA.1 = 0
Call fillScreen(LCD_WHITE)
Call LCD_DrawLine(10,10,310,230,LCD_BLACK)
Call LCD_DrawLine(310,10,10,230,LCD_BLACK)
Call LCD_DrawLine(10,120,310,120,LCD_BLACK)
Call LCD_DrawLine(160,10,160,230,LCD_BLACK)
Call LCD_Circle(160,120,100,LCD_BLUE)
Call fillwindow(100,50,220,190, LCD_WHITE)
Call LCD_DrawRectangle(100,50,220,190,LCD_BLUE)
WaitMs 1000
Wend
End
Proc SPI_init()
SSPSTAT = 0x40
SSPCON1 = 0x31
End Proc
Proc LCD_WRITE_COM(dat As Byte)
TFT_CS = 0
TFT_DC = 0
SSPBUF = dat
While SSPSTAT.BF = 0
Wend
TFT_DC = 1
TFT_CS = 1
End Proc
Proc LCD_WRITE_DATA(dat As Byte)
TFT_CS = 0
TFT_DC = 1
SSPBUF = dat
Wend
TFT_DC = 1
TFT_CS = 1
End Proc
Proc LCD_init()
Dim idx As Byte
Dim cmd As Byte
High TFT_RST
'ConfigPin TFT_RST = Output
WaitMs 100
Low TFT_RST
WaitMs 100
High TFT_RST
WaitMs 200
Call LCD_WRITE_COM(ILI9341_SWRESET)
WaitMs 150
Call LCD_WRITE_COM(ILI9341_DISPOFF)
Call LCD_WRITE_COM(0xCB) //Power control a
Call LCD_WRITE_DATA(0x39)
Call LCD_WRITE_DATA(0x2C)
Call LCD_WRITE_DATA(0x00)
Call LCD_WRITE_DATA(0x34)
Call LCD_WRITE_DATA(0x02)
WaitMs 1
Call LCD_WRITE_COM(0xCF) //Power control b
Call LCD_WRITE_DATA(0XC1)
Call LCD_WRITE_DATA(0X30)
WaitMs 1
Call LCD_WRITE_COM(0xE8) //Timing control a
Call LCD_WRITE_DATA(0x85)
Call LCD_WRITE_DATA(0x10)
Call LCD_WRITE_DATA(0x78)
WaitMs 1
Call LCD_WRITE_COM(0xEA) //Timing control b
WaitMs 1
Call LCD_WRITE_COM(0xED) //Power on seq control
Call LCD_WRITE_DATA(0x64)
Call LCD_WRITE_DATA(0x03)
Call LCD_WRITE_DATA(0X12)
Call LCD_WRITE_DATA(0X81)
//WaitMs 1
Call LCD_WRITE_COM(0xC0) //Power control 1
Call LCD_WRITE_DATA(0x26) //VRH[5:0]
//WaitMs 1
Call LCD_WRITE_COM(0xC1) //Power control 2
Call LCD_WRITE_DATA(0x11) //SAP[2:0];BT[3:0]
//WaitMs 1
Call LCD_WRITE_COM(0xC5) //VCM control
Call LCD_WRITE_DATA(0x3e) //Contrast
Call LCD_WRITE_DATA(0x28)
// WaitMs 1
Call LCD_WRITE_COM(0xF7)
Call LCD_WRITE_DATA(0x20)
//WaitMs 1
Call LCD_WRITE_COM(ILI9341_MADCTL)
Call LCD_WRITE_DATA(0x8)
Call LCD_WRITE_COM(ILI9341_INVOFF)
//WaitMs 1
Call LCD_WRITE_COM(ILI9341_NORON)
WaitMs 1
Call LCD_WRITE_COM(ILI9341_COLMOD )
Call LCD_WRITE_DATA(0x55)
//WaitMs 1
Call LCD_WRITE_COM(0xB7) //emtry mode
Call LCD_WRITE_DATA(0x07)
Call LCD_WRITE_COM(0x3A) //pixel format
Call LCD_WRITE_DATA(0x55) //16bit
Call LCD_WRITE_COM(ILI9341_DISP_FUNC) // Display Function Control
Call LCD_WRITE_DATA(0x08)
Call LCD_WRITE_DATA(0x82)
Call LCD_WRITE_DATA(0x27)
WaitMs 1
Call LCD_WRITE_COM(ILI9341_SLPOUT)
WaitMs 120
Call LCD_WRITE_COM(ILI9341_DISPON)
WaitMs 1
LCD_height = 240
LCD_width = 320
End Proc
'@brief SPI displays set an address window rectangle For blitting pixels
'@param x Top left corner x coordinate
'@param y Top left corner x coordinate
'@param W Width of window
'@param h Height of window
Proc setAddrWindow(x1 As Word, y1 As Word, x2 As Word, y2 As Word)
Call LCD_WRITE_COM(ILI9341_CASET) //Column addr set
Call LCD_WRITE_DATA(x1.HB)
Call LCD_WRITE_DATA(x1.LB)
Call LCD_WRITE_DATA(x2.HB)
Call LCD_WRITE_DATA(x2.LB)
Call LCD_WRITE_COM(ILI9341_RASET) //Row addr set
Call LCD_WRITE_DATA(y1.HB)
Call LCD_WRITE_DATA(y1.LB)
Call LCD_WRITE_DATA(y2.HB)
Call LCD_WRITE_DATA(y2.LB)
Call LCD_WRITE_COM(ILI9341_RAMWR) //write to RAM
End Proc
Proc LCD_DrawLine(x1 As Word, y1 As Word, x2 As Word, y2 As Word, color As Word)
Dim t As Word
Dim xerr, yerr, delta_x, delta_y, distance As Integer
Dim incx, incy, xPix, yPix As Integer
xerr = 0
yerr = 0
delta_x = x2 - x1
delta_y = y2 - y1
xPix = x1
yPix = y1
If delta_x > 0 Then incx = 1
If delta_x = 0 Then incx = 0
If delta_x < 0 Then
incx = -1
delta_x = -delta_x
Endif
If delta_y > 0 Then incy = 1
If delta_y = 0 Then incy = 0
If delta_y < 0 Then
incy = -1
delta_y = -delta_y
Endif
If delta_x > delta_y Then
distance = delta_x
Else
distance = delta_y
Endif
For t = 0 To distance + 1 Step 1
Call LCD_DrawPoint(xPix, yPix, color)
xerr = xerr + delta_x
yerr = yerr + delta_y
If xerr > distance Then
xerr = xerr - distance
xPix = xPix + incx
Endif
If yerr > distance Then
yerr = yerr - distance
yPix = yPix + incy
Endif
Next t
End Proc
Proc LCD_String( str As String, x As Word, y As Word, size As Word , fcol As Word , bcol As Word)
Dim x0 As Integer
Dim width, height As Integer
Select Case size
Case 1
width = 5
height = 8
Case 2
width = 8
height = 12
Case 3
width = 16
height = 24
EndSelect
x0 = x
width+=x
height+=y
End Proc
// Rectangle
Proc LCD_DrawRectangle( x1 As Integer, y1 As Integer, x2 As Integer, y2 As Integer, color As Word)
Call LCD_DrawLine(x1, y1, x2, y1, color)
Call LCD_DrawLine(x1, y1, x1, y2, color)
Call LCD_DrawLine(x1, y2, x2, y2, color)
Call LCD_DrawLine(x2, y1, x2, y2, color)
End Proc
// Circle routine
Proc LCD_Circle(x1 As Word, y1 As Word, rad As Word, color As Word)
Dim xPix, yPix, di As Integer
xPix = 0
yPix = rad
di = 3 - ShiftLeft(rad,1)
While xPix <= yPix
Call LCD_DrawPoint(x1+xPix, y1-yPix, color)
Call LCD_DrawPoint(x1+yPix, y1-xPix, color)
Call LCD_DrawPoint(x1+yPix, y1+xPix, color)
Call LCD_DrawPoint(x1+xPix, y1+yPix, color)
Call LCD_DrawPoint(x1-xPix, y1+yPix, color)
Call LCD_DrawPoint(x1-yPix, y1+xPix, color)
Call LCD_DrawPoint(x1-xPix, y1-yPix, color)
Call LCD_DrawPoint(x1-yPix, y1-xPix, color)
xPix = xPix + 1
If di < 0 Then
di= (4 * xPix + 6) + di
Else
di= (10 + 4 * (xPix-yPix)) + di
yPix = yPix - 1
Endif
Wend
End Proc
// line drawing
Proc LCD_DrawPoint(x1 As Word, y1 As Word ,color As Word)
Call LCD_WRITE_DATA(color.HB)
Call LCD_WRITE_DATA(color.LB)
End Proc
Proc fillRect(x1 As Word, y1 As Word, x2 As Word, y2 As Word, color As Word)
Dim px As Long
Dim tmp As Word
If x2 > 0 And y2 > 0 Then //Nonzero width and height?
Call setAddrWindow(x1, y1, x2, y2)
px = x2
px = px * y2
TFT_CS = 0
TFT_DC = 1
While px > 1
SSPBUF = color.HB
Wend
SSPBUF = color.LB
Wend
px = px - 1
Wend
TFT_DC = 1
TFT_CS = 1
Endif
End Proc
'@brief Fill the screen completely with one color. Update in subclasses If desired!
'@param color 16-Bit 5-6-5 Color To fill with
Proc fillScreen(color As Word)
Call fillRect(0, 0, LCD_width, LCD_height, color)
End Proc
Proc fillwindow(x1 As Word,y1 As Word,x2 As Word,y2 As Word,color As Word)
Call fillRect(x1, y1, x2, y2, color)
End Proc
