So basically diodes can set off a chain reaction while in parallel because of the slight difference in breakdown current?Something to think about:
Components in a serial connect must have the same current flowing through them. There is no other path to take. So putting 3 diodes or 3 resistors or whatever in series can't improve the current rating over a single component, as they will all see the same current.
If components are in parallel, they will all have the same voltage across them. So putting components in parallel can't change the voltage rating.
Beyond that, depending on components, there will be complications as Nigel said. Let's consider a simple case. Three 10k resistors in parallel. They will have the same voltage across them, and each should carry ⅓ of the current, right? It's not quite that simple, as 10k resistors aren't exactly 10k ohms. The one with the lowest resistance is going to carry more than its share of the current. But that's going to cause it to get hotter, and increase in resistance.... eventually, they'll reach equilibrium.
With diodes, the situation is much more complicated.
i've seen low-end AV receivers that use parallel bridge rectifiers in the amp power supply.... they fail often because of differences in Vf causing one of them to have more current... as silicon heats up, Vf reduces by 2.2mV/degC, so the diode drawing more current will heat up faster, further reducing it's Vf, and further increasing it's share of the current... you can see where this is going...
=)The was a manufacturer of early cheap B&W TVs in Los Angeles (Muntz TV) whose owner called himself Madman Muntz (he was the first to coin the word "TV").
From Wikipedia:
He often carried a pair of wire clippers, and when he thought that one of his employees was "overengineering" a circuit, he would begin snipping components out until the picture or sound stopped working. At that point, he would tell the engineer "Well, I guess you have to put that last part back in" and walk away.
Perhaps there still a version of him working in some of our factories today.
From Wikipedia:
