martianent
Okay, it's been a while since I've been on here, wondering about the best way to go about building a 4-digit tachometer. I've gotten a new book by the same guy where I had gotten the tach idea, which includes schematics for a full digital instrument cluster. However, it has occurred to me that there seems to be a TON of unnecessary parts in these plans IF I choose to use a microcontroller as was suggested to me in the other topic.
My goals are the following:
LED DISPLAY. NOT LCD. When the gauge cluster is assembled for the factory dashboard, I WILL NOT have any room for an LCD. Period. The factory gauge holes are too small, which would make reading an LCD difficult at best.
Cheap. As in UNDER $400, the point at which I could buy a Dakota Digital gauge set and have to seriously modify the boards to fit in my cluster housing.
The gauges to be made are:
10 LED bar fuel gauge, resistance of 90 ohms full and none empty.
10 LED bar engine manifold vacuum gauge using a spare Motorola MPX4250APX I won't be using in my replacement engine controller. I think the maximum output of the 4250 is 5 VDC, but I need to dig up my datasheet to confirm. If not, I have a spare factory manifold pressure sensor that DOES have a maximum output of 5 VDC that I will need to add wires for through a couple of connectors before running to the gauge cluster.
Combination bar and digital 7-segment 3 digit readouts:
Battery voltage gauge, 8 to 18 VDC.
Intake air temperature gauge, probably somewhere between 20*F and 120*F
Coolant temperature gauge, maximum reading of about 260*F before I would like the display to flash if possible.
Engine oil pressure gauge, 0 to 70 PSI (yes, it seems high but the engine oil pump regulator is set to max pressure of 70 PSI from the factory), 2-digits. All 3 of these temp and pressure senders have a max output voltage of 5 VDC.
The big ones, at least 20 (between 20 and 30) LED bar graph and 4-digit segment display:
Engine tachometer, 6500 RPM maximum, 6 cylinder. Currently have an analog tach.
Vehicle speed indicator, maximum of 150 MPH. Currently have an electronically-driven analog gauge with 2000 pulses per mile (PPM) on 13" radius tires (26" diameter).
I have been researching this like crazy the last week or so now that winter is coming and I have a little less to do outside, and the only things I can come up with don't come close to my dilemma and most have an LCD display.
I have another gauge cluster from another car that has a VTF (I think that's how it's abbreviated) display. This display includes: bar fuel gauge, speedometer in either MPH or Km/H, trip odometer, vehicle odometer (non-resettable). I would reverse-engineer this thing but I can't find datasheets on what was apparently custom-made chips. The rest of the gauges are analog.
Which leads me to my last problem: The schematic in the new book for the digital speedometer also has an additional circuit for a digital odometer. However, I do NOT want to have to reset this odometer if the battery lies dead for 10 days (how long it takes before the backup circuit in the digital odo loses power), say, during winter storage for 3-5 months. Which is why I was hoping I could at least build the tachometer (using the MAX7221 display driver) and the speedometer (probably using the same chip) with the attached odometer (MAX7221 with EEPROM for memory storage) using a microcontroller, which would probably reduce parts significantly. And yes, I know about the legality issue, which is why I plan on retaining the factory speedometer for the original odometer, in case things go batty, hidden behind a couple of heating vents which no longer connect to the heating duct.
I was thinking it would be easier to have the inputs go into the microcontroller for the frequency measurement off of the vehicle speed sensor output and the tachometer feed from the ignition, and then use an A/D converter (CA3162E is mentioned but seems useless) for each of the voltage inputs for the other gauges.
I just need a mention of a decent microcontroller and the rest of the ICs, of which I will dig up datasheets and draw schematics accordingly until I get something I can use. Coding will come later when I get my hands on a programmer (have a chip to read as well for another purpose).
