Defining a delay
Kryten
Is it possible to define a delay if i shall use it several times
I mean I can define ports as names for easy programming and give low or high output short names like
#define LED_OFF output_low
Can I do the same with a delay?
I looking to turn off (or on) several outputs for a short period of time (250ms)
will it make sense to do it like this?
#define LED_blink output_low delay(250ms) output_high
Yes, you create a subroutine for the delay_loop.
You then CALL delay_loop or GOTO delay_loop when ever you need it.
The value currently held in W can be carried into the subroutine if needed.
A Macro can be also used to do similar things.
Ok I might have been a bit vague. Im programming in C because im trying to control via USB
Im using (i belive its called) Hi Tech pic c compiler (the one that comes with mplab) and 18F4550 (PIC that is).
Im going to use 12MHz crystall and running it a 4x (48MHz)
