williB
below is the output from MPLAB
my question is how should the Target pic be hooked up physically , to get the debug feature to work?
see below
below is a pascal pgm to output the adc to ports B & D on a 877A.
Nigel will like this..
the problem is when i compile it and get the Hex output file Imported into MPLAB , i get the IDC 00083 Debug error .
i have the config bits selected to use the built in RC oscillator
see below
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to MPLAB ICD 2
Target Device PIC16F877A found, revision = b4
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
Resetting Target
Resetting Target
MPLAB ICD 2 Ready
MPLAB ICD 2 Ready
Programming Target...
...Validating configuration fields
...Erasing Part
...Programming Program Memory (0x0 - 0x6F)
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
Connecting to debug executive
ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information.
MPLAB ICD 2 Ready
program adconthe877A;
var temp_res : word;
begin
ADCON1 := $80; // Configure analog inputs and Vref
TRISA := $FF; // PORTA is input
TRISB := $3F; // Pins RB7 and RB6 are output
TRISD := $0; // PORTD is output
while TRUE do
begin
temp_res := Adc_Read(0);
PORTD := temp_res; // Send lower 8 bits to PORTD
PORTB := word(temp_res shr 2); // Send 2 most significant bits to PORTB
end;
end.
