Mr HG
I'm working on a project where I control the regulation of the water level in tanks from the PC via a microcontroller STM32.
My problem is this: when I am sending a low duty cycle (less than 40%) at the pump, it does not rotate! This then causes a response delay of the system so that the controller sends 100% .. The control signal of the pump thus resembles a PWM signal! 0% or 100%!
Is this problem is the circuit of the power amplifier https://www.electro-tech-online.com/attachments/power-amplifier-jpg.83626/ (I use NPN transistors instead of IGBT, ie running attack and not voltage)? Or should I define a dead zone for the pump in the program?
Is the circuit of the power amplifier has a role in this problem?
Do you have any ideas for improvement? solutions?
