Hello all,
I am trying to build an adjustable current limiting circuit. The supply is fixed at 5V, but can supply between 0-50A, I want to limit it to a maximum of 48A, but also have it adjustable between 0A and 48A.
So here are the specs:
Vs = 5V
Imax = 48A
If I could use BJT's, Rsense was going to be 2 resistors, one 0.015 Ohm 50W resistor, in series with a 1 Ohm 50W adjustable power resistor.
I have found an IGBT with the following specs
Vces = 600V
Vce(sat) < 2.6V
Ic (100C) = 55A, Ic (25C) = 100A
Vge = +- 20V
I have this diagram (below) but it uses BJTs and I cant seem to figure out how to modify it for using IGBTs because I have never used them before.
Normally I would start by choosing a transistor that can handle the Vs and Imax, then calculate the base current of Q1 using Imax and Hfe but there is no Hfe with IGBTs? I am at a loss since I will need to use IGBTs. I need some help!
I was also going to use some large resistors and adjustable power resistors, around 50W, for Rsense.
If you guys have any better way to have an adjustable current limit of 0A to 48A with a fixed 5V, than this circuit let me know!
Vs = 5V
Imax = 48A
Vces = 600V
Vce(sat) < 2.6V
Vge = +- 20V
