I am soldering an external switch onto the front circuit board power button of a CRT television. I had the ground soldered in place on the board and switch, and the connecting wire on the switch but not the board. The TV was on and the loose end of the connecting wire came in close proximity to the screen of the TV and it shut off (I was testing if the switch would work, touching the wire to the contact, which is why the tv was on). Now the TV won't come back on, even with the regular power button. I tried connecting the switch with the ground and power wires, and nothing. Is there something in the front circuit board (power, channel, volume, etc) that, along with the switch, powers the TV? Can I bypass this board?
The real question is can I power on the TV without the front circuit board (remove it)?
I am building a MAME cabinet, which is why I'm messing with the tv in the first place...
Thanks for your help in advance, I'm new here (the forums AND the field).
